Pumping away question.
hot_rod
hot_rod Member Posts: 26,602
will work. I like the Hydrolink port as it provides a nice solid mount to hang from. Be sure to use the upper port for an air vent. That mix chamber acts as an air (purger) trap. I think Caleffi includes one with the 'link.
I like to add an air vent up high on the Ultras. If you don't use the upper connection that's a great place to add one.
The Knights and a few others have a factory installed air vent right on the HX header.
hot rod
