Hot Water Coils
try US Coil and air, I think there is a ratings calculator on their web site...
  • Paul Fredricks_3
    Paul Fredricks_3 Member Posts: 1,556
    Looking
    Does anyone know where I can find an output chart for duct mounted hot water coils? I looked around on line, but can only find dimensions. I'm looking for btu output at a given cfm, temp and flow.
    Specifically, We have a customer with a 20 x 14 2 row, 3/8" coil in a 2 ton air handler.
  • Brad White
    Brad White Member Posts: 2,399
    What might also help
    is knowing the fins per inch (FPI) density and the circuiting. By circuiting, is the pathway a serpentine or several parallel runs? And is each row a separate circuit or is the second row the "back pass" in series to the first row?
    All of these things affect output.
    If you dig a bit, you may find a label with the criteria on it.
    "If you do not know the answer, say, "I do not know the answer", and you will be correct!"
    -Ernie White, my Dad
  • coil BTU's
    Great listing at www.magicaire.com
