Hot Water Coils
Tom Blackwell_2
Member Posts: 126
try US Coil and air, I think there is a ratings calculator on their web site...
Looking
Does anyone know where I can find an output chart for duct mounted hot water coils? I looked around on line, but can only find dimensions. I'm looking for btu output at a given cfm, temp and flow.
Specifically, We have a customer with a 20 x 14 2 row, 3/8" coil in a 2 ton air handler.0 -
What might also help
is knowing the fins per inch (FPI) density and the circuiting. By circuiting, is the pathway a serpentine or several parallel runs? And is each row a separate circuit or is the second row the "back pass" in series to the first row?
All of these things affect output.
If you dig a bit, you may find a label with the criteria on it."If you do not know the answer, say, "I do not know the answer", and you will be correct!"
-Ernie White, my Dad0 -
coil BTU's
Great listing at www.magicaire.com0
- 87K THE MAIN WALL
- 57 Biomass
- 116 Chimneys & Flues
- 5.7K Gas Heating
- 109 Geothermal
- 70 Pipe Deterioration
- 986 Plumbing
- 6.3K Radiant Heating
- 389 Solar
- 15.4K Strictly Steam
- 44 Industry Classes
- 48 Job Opportunities
