Cold weather balancing?
I need to balance a couple of ac systems is there a way to so when the space is 65*F . I tried running the heat to bring up temp but it was to warm for boiler contol!! Thanks Jeff
  • Techman
    Techman Member Posts: 2,143
    Cool Weather
    Most mfr's have charging charts,check with them . Will these unit be running when the outdoor air temp's are cool ?
  • Empire_2
    Empire_2 Member Posts: 2,340
    50* or higher
    Stumbling Thur the fragmented sentence, .....What???
    Balance? What do you mean?
    Carrier has a nice slide rule which may help you determining your total charge if that is what you are looking for.
    Mike T.
