Cold weather balancing?
Jeff Elston
Member Posts: 289
I need to balance a couple of ac systems is there a way to so when the space is 65*F . I tried running the heat to bring up temp but it was to warm for boiler contol!! Thanks Jeff
Cool Weather
Most mfr's have charging charts,check with them . Will these unit be running when the outdoor air temp's are cool ?0 -
50* or higher
Stumbling Thur the fragmented sentence, .....What???
Balance? What do you mean?
Carrier has a nice slide rule which may help you determining your total charge if that is what you are looking for.
Mike T.0
- 87.4K THE MAIN WALL
- 122 Chimneys & Flues
- 15.8K Strictly Steam
