Wayne MSR Burner problem
burnerman_2
burnerman_2 Member Posts: 297
i took the burner off took it to a work bench it lite with a test transformer and as u said if u lift up the transformer well it turned out to be a cracked porcelin they are harder to see because of the way they are in the drawer assemely so try this okie dokie royboy
  • John L._2
    John L._2 Member Posts: 1
    I Have a burner that will not start up all the time unless I lift up the transformer and put It back down then hit the
    restart button. I have checked the contacts and they look fine and make good contact but I have no idea what could be causing this. When it starts it runs fine.
  • Weezbo
    Weezbo Member Posts: 6,231
    too much heat on the transformer...
    melts the potting material, this in turn changes the performance of a transformer.
    ambient temps are a biggie also. i also agree with slight fractures in the electrode porcelain..
    if the wires are "Baked" leading to the transformer it is an indicator.
