What is a sweeping tee?
Brad Meadows_2
Member Posts: 2
What is a sweeping tee? My contractor claims it is a boiler part not a plumbing part. He says its brass and it goes to copper.
perhaps better known as monoflow tee
They are brass and used in hydronic systems to create a pressure drop to force flow through a heat emmiter.0 -
Sweeping
These tees double as helpers and sweep the floor when needed:)
I never heard of a sweeping tee0 -
same here
Same here, in my 30 plus years in plumbing/heating/drainage business, never heard of sweeping tee... Where did ya hear that term from? Mr orange vest guy?0 -
Perhaps.........
.........the reference is to a "sweep tee" or a tee with a long sweep in the bull?0 -
maybe he means a copper wye? they where common back in the day0 -
Yes Yes
It fits on the bottom of the broom. Very popular in the west.
I love some of the names my guys have brought up.
Scott
Long turn tee wye
In my area I have heard some o f the younger guys refer to a long turn tee wye as a " sweeping tee" or a "long sweep tee" But then for many years I would call unistrut "kindorf" and most people still refer to tissues as "kleenex"
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"There was an error rendering this rich post.
Yeah, sure sounds like a combo wye for DWV. What are you using this for?0 -
mono flow tee
I think he might be refering to a mono flow tee?
Steve0 -
the scoop
An alternate name for monoflow tee [ which is patented by b.& g. ] is scoop tee. also taco made venturi tee's0 -
Brad
maybe he is hoping it will sweep up his mess for him. Brass goes to to copper -- and what does that have to do with heating? He's out of his gord.
Jed0 -
heard of a
HAs anyone heard of a "jiffy ell"0 -
brass to copper
Sounds like he has a brass or bronze fitting with socket ends for a copper tube system [sweat ] as opposed to iron pipe size female for a steel pipe threaded system. fairly common.0 -
I have heard Sanitary T's and T-Y's called Sweep T's but not very often.0 -
Long Sweep 90,
vent t,san t, combo,long sweep combo. Two way cleanout.
vent 90,regular 90,drainage 90 long sweep 90
y combo....short turn 90's and long turn 90's ...
?0 -
Brad
I've not heard that term..........ever.
What was the topic of your discussion with your contractor when this term came up? What did he say this fitting did in particular and why does he need it?
I'm just looking for clues as to what the intended use of the fitting actually is. Maybe that will help us determine what he's talking about.
I'm curious because in 30 years of hardware store, plumbing and heating experience I have never heard of this term.0 -
How about \"session joint, rosco wye, & long screw?
Do these have any rememberance?0 -
Jiffy
Jiffy fittings are made by the Fernco Company. You can cut out a damaged drainage fitting and replace it with a one piece all rubber fitting with clamps at each joint.0 -
rubber workers
you can save more time & money by just using rubber hoses. real craftsmanship0 -
the not plumbers techniques
ah, the sission joint . when you could eliminmate the necessary three sections of pipe to cut in a fitting on a cast iron soil line. at best is was a slopass joint and also illegal. the kaffir joint with the screw hub was the more acceptable way to go if you wanted to slide in a quick job and beat the system. this is why there are codes and licensed plumbers. to try and curtail the fly by nite butchers. saddles were also big timesaver0 -
When working in NYC
we called, what I know now as a long turn tee wye,a Boston tee wye and of course this is use in a plumbing waste or drainage system. Maybe now it is called a sweeping tee but never heard of it.
I still call it "Kindorf"0 -
Kindorf
When I asked for kindorf in a new jersey supply house they looked at me sideways. after I discribed it they sold me unistrut.
- 167 Indoor-Air Quality
