ergomax indirect
Mark Eatherton
Member Posts: 5,874
TURBOmax. Great product. Fantastic performance. Too new to rate as it pertains to life expectancies...
ME
ME
Indirect water heater
Anyone with significant experience with Ergomax indirect water heaters? Or should I stick with the big names?si0 -
ERGOMAX
The ergomax lit that i've seen shows them as an interesting concept, sort of a reverse indirect. The tank is full of boiler water and the domestic goes up thru it in multiple coils. according to a rep I know there real slick, but everything he reps is supposed to be real slick. They would work great as a buffer for a mod-con.
I got One
Lifetime warranty on the tank when I bought it. Tank started leaking at about 9 years, they gave me a new one. Thermostat went bad after 3 years. I paid for that. Got 'er hitched up to a Teledyne Laars, never run out of hot water, not matter what I do, fill the hot tub, power washer, whatever....0 -
Hey Mike how many BTu's is your boiler that is feeding the ergomax??
I was wondering if a 100k btu boiler can keep up with the 1st hour ratings?
I have one, an E44
It is hooked in series in the primary loop to add boiler content as well as produce DHW. Two Biasi 80,000 net boilers. If I were to do this again, I would buy a reverse indirect but NOT Ergomax. I am not impressed with their assembly quality as mine has a tank rusting from the outside in under the aquastat well.0 -
one thing to watch
hard water, and low DHW flow rates. I had one plug up the header plate where all those coils come together, from hard water deposits.
I installed it as mainly a buffer tank for a waste oil boiler. it supplied hot water to a few hand sinks.
I found the workmanship and very minimal insulation a bit disappointing. This was a few years back, perhaps they have made some upgrades.
With enough horsepower they perform very well.
hot rodBob "hot rod" Rohr
Thanks
to all-I think I've narrowed it to WM, Triangle tube makes theirs, or the Superstor. Hope these work ok with Knight.0 -
Lochinvar offers a nice indirect tank, also
it may in fact be the same tank Crown offered as the MegaStor for years. A solid performer with an excellent following.
And it matches the Knight's jacket colors!
Safety
is concern too. Do codes require HEx in upgraded systems? I mean to separate the potable from horrible by more than one layer of metal.0
- 120 Geothermal
