ergomax indirect
Mark Eatherton
Mark Eatherton Member Posts: 5,874
TURBOmax. Great product. Fantastic performance. Too new to rate as it pertains to life expectancies...
ME
  • Buzz G.
    Buzz G. Member Posts: 61
    Indirect water heater
    Anyone with significant experience with Ergomax indirect water heaters? Or should I stick with the big names?si
  • martin
    martin Member Posts: 144
    ERGOMAX
    The ergomax lit that i've seen shows them as an interesting concept, sort of a reverse indirect. The tank is full of boiler water and the domestic goes up thru it in multiple coils. according to a rep I know there real slick, but everything he reps is supposed to be real slick. They would work great as a buffer for a mod-con.
  • Mike Thomas_2
    Mike Thomas_2 Member Posts: 109
    I got One
    Lifetime warranty on the tank when I bought it. Tank started leaking at about 9 years, they gave me a new one. Thermostat went bad after 3 years. I paid for that. Got 'er hitched up to a Teledyne Laars, never run out of hot water, not matter what I do, fill the hot tub, power washer, whatever....
  • chris_93
    chris_93 Member Posts: 84
    Hey Mike how many BTu's is your boiler that is feeding the ergomax??
    I was wondering if a 100k btu boiler can keep up with the 1st hour ratings?
  • Maine Doug_66
    Maine Doug_66 Member Posts: 28
    I have one, an E44
    It is hooked in series in the primary loop to add boiler content as well as produce DHW. Two Biasi 80,000 net boilers. If I were to do this again, I would buy a reverse indirect but NOT Ergomax. I am not impressed with their assembly quality as mine has a tank rusting from the outside in under the aquastat well.
    hot_rod Member Posts: 27,473
    one thing to watch
    hard water, and low DHW flow rates. I had one plug up the header plate where all those coils come together, from hard water deposits.
    I installed it as mainly a buffer tank for a waste oil boiler. it supplied hot water to a few hand sinks.
    I found the workmanship and very minimal insulation a bit disappointing. This was a few years back, perhaps they have made some upgrades.
    With enough horsepower they perform very well.
    hot rod
  • Buzz G.
    to all-I think I've narrowed it to WM, Triangle tube makes theirs, or the Superstor. Hope these work ok with Knight.
    Lochinvar offers a nice indirect tank, also
    it may in fact be the same tank Crown offered as the MegaStor for years. A solid performer with an excellent following.
    And it matches the Knight's jacket colors!
    hot rod
  • Buzz G.
    Safety
    is concern too. Do codes require HEx in upgraded systems? I mean to separate the potable from horrible by more than one layer of metal.
