GB142-60
RianS
Member Posts: 104
Evening all,
Does anyone know what the first hour and continuous flow rating is on the 50 gallon indirect using the GB142-60?? I want to use this combo. on a job coming up but the web-site is hard to get info from. Thanks in advance. RianS
RianS
Which 50 gallon indirect would that be?
Darin0 -
Flow rate
It is recommended to use a Taco 0013 or equal with the Buderus ST200 (53 gallon tank)and the GB142/60. If other tank is being used, The GB142/60 has 10ft of head at 16GPM. 31/2 feet of head at 9GPM. Please call if there are any questions.0 -
I think he is looking for the output of the indirect, not the flow required throught the heat exchanger. I have it at home i believe.....0 -
Hey Joe,
What is the pressure drop across this boiler? I can't find that in your literature.0 -
I am looking for the output of the ST200 at the BTU rating of the GB142-60. It is going in a 10,500 sq ft home with 7 bathrooms. The master bath has a 210 gallon whirlpool tub. Just want to have enough to handle a couple of showers at the same time. Get this, the well is rated at 8 gpm, I am sure the shower in the master bath alone needs more than that with all the body sprays and shower head. This system will be 12 zones of radiant already piped with circulators and 1 zone for indirect. All the tubing is done and most of the piping to the boiler room. The basement zones are all tied together and connected to an electric water heater for some heat this past winter. Thats all the previous contractor completed before he passed away. Although the work is very nice, I am trying to figure out what he had in mind when planning the system. He was going to use 2 Polaris gas water heaters, 1 for heat and 1 for domestic hot water. It almost looks like he was going to supply the entire heating system with 1 water temp., I guess its possible since all the floors are concrete. Any advise on how to approach this job would be appreciated. Thanks RianS0 -
I would tread VERY carefully with this project..................
Are you coming in on the end?????? Sounds like alot of higher expectations here. Where you involved with the roughing/calculating at all? Mad Dog
ST200 output
The ST200 with a GB142/60 will have a 199GPH continuous rating (3.3gpm). Based on the information provided the domestic hot water production should be looked at.0 -
Mad Dog
I wasn't involved with any of the load calcs., planning or anything. All I was able to get from the HO was info. on the Polaris water heaters and the heat loss was 195,000 BTU's. The heat loss was calculated with R-19 in exterior walls and R-30 in the ceilings. The home is all concrete exterior walls which is poured into styrofoam forms which is actually around R-50. I am having my own heat loss done on it but I am still guessing what the previous contractor had in mind. Thanks Joe for the info on the ST0
- 85.7K THE MAIN WALL
- 49 Biomass
- 73 Chimneys & Flues
- 92 Geothermal
- 150 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 852 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
