Anticipator and Thermostat
Larry_10
Member Posts: 127
ammeter
I think you already have your answer. Go to your local supply house and get an ammeter, and do it right, and be done.0 -
what if your tstat is connected through a relay because your gas train requires too much current for the tstat?
Brian0 -
What works
I would agree that using an ammeter is a good idea, the more you use it the more likely you will use it and it's a useful tool, too much amps kills most electrically dead heating parts. So, ever wonder why the anticipator is adjustable,= to get about 6 cycles per hour with a variable load (gas valve circuit) on a warm air furnace. If you have a boiler,especially steam do you want 6 cycles per hour? No, then set it higher, I have found the little slider to be somewhat inaccurate so I use and ammeter to get the highest setting for steam. A bit less high for HW cast iron rads and less for baseboard. Too low is often bad since many powerstealing stats need a constant draw, that's why the resistor is often found tied to W and C. To give a false load to keep the stat working.0 -
someone is using my author name please look before you post I did not post the above message0 -
Apologies to Roosterboy
I have been posting about main vents, anticipators, thermostats, and pressuretrols - - under Roosterboy.
I thought that was a name that was automatically generated for me to use. It kept reinserting itself in the sender info boxes. Anyway it has been corrected and my apologies for any inconvenience.
Thanks for the info
Thanks for all the advices guys, I'll go with the ammeter.0
- 120 Geothermal
- 169 Indoor-Air Quality
- 396 Solar
