Anticipator and Thermostat
Larry_10
Larry_10 Member Posts: 127
  • Larry_10
  • m_3
    m_3 Member Posts: 19
    ammeter
    I think you already have your answer. Go to your local supply house and get an ammeter, and do it right, and be done.
  • brian_27
    brian_27 Member Posts: 7
    what if your tstat is connected through a relay because your gas train requires too much current for the tstat?
    Brian
  • Dale
    Dale Member Posts: 1,317
    What works
    I would agree that using an ammeter is a good idea, the more you use it the more likely you will use it and it's a useful tool, too much amps kills most electrically dead heating parts. So, ever wonder why the anticipator is adjustable,= to get about 6 cycles per hour with a variable load (gas valve circuit) on a warm air furnace. If you have a boiler,especially steam do you want 6 cycles per hour? No, then set it higher, I have found the little slider to be somewhat inaccurate so I use and ammeter to get the highest setting for steam. A bit less high for HW cast iron rads and less for baseboard. Too low is often bad since many powerstealing stats need a constant draw, that's why the resistor is often found tied to W and C. To give a false load to keep the stat working.
  • Larry_10
    someone is using my author name please look before you post I did not post the above message
  • Larry_10
    Apologies to Roosterboy
    I have been posting about main vents, anticipators, thermostats, and pressuretrols - - under Roosterboy.
    I thought that was a name that was automatically generated for me to use. It kept reinserting itself in the sender info boxes. Anyway it has been corrected and my apologies for any inconvenience.
  • Larry_10
    Thanks for the info
    Thanks for all the advices guys, I'll go with the ammeter.
