Multi-zone primary-secondary help...
hvacfreak
Member Posts: 439
I am building a multiple zone manifold (injection) and I have chosen to drop from the the bottom of the main and thermal trap up ( 12 inches ) with the circuit take-offs. The last job I did with multi-injection we came out of the top of the main and actually had flow through some zones that were not calling ( I did not select the circulators , and yes we had 6 inches center to center on suply / return take-offs. ). Right now the manifold is just copper pipe ( no components installed ).
Will my thermal traps help avoid this unwanted flow possibility ( Dan's book says no , lol..but I ordered it too late )? Should I plan on check valves on both supply and return take-offs ? I just want to use on/off ( not variable )control circulators ( or is this where I'm kidding myself ). All replies appriciated.
- Mike
- Mike
There is some science to thermal drops
merely droping the pipe below the P/S connection may not cut it. Ask me how I know.
An astute hydronic contractor wiz in upstate NY was able to shine the light for me. Thanks Harvey.
Check out this article before you
proceed.http://www.pmmag.com/CDA/Archives/2df7e8c55e028010VgnVCM100000f932a8c0____
hot rod
it seems....
that I missed the boat on my way of thinking. Thanks for that information.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 73 Chimneys & Flues
- 92 Geothermal
- 150 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 851 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
