Grundfos Comfort System recirc. Anyone use it ?
Brad White
Brad White Member Posts: 2,399
the single-piece circulator, timer and temperature switch with the up-turned tail (sort of like a shy scorpion with a vial of Viagra in the check-out line at Rite-Aid)?
If so, yes, I have one and put one in my sister's house.
Mine seized for some reason and I will take it apart but when it worked it worked well.
"If you do not know the answer, say, "I do not know the answer", and you will be correct!"
-Ernie White, my Dad
