Residential 30psi Boiler Relief Valve drips in summmer, Why?
jrh_2
Member Posts: 1
Residential 30 psi. Hot Water Boiler Relief Valve drips in summer. Drips about .25 gal in 24 hours. Why? I have replaced relief valve twice in two days. Continues to drip. What could I do or check to stop this problem.
Why?
Water psi set to high. But most likely reason is a waterlogged compression tank or a under pressurized x-tank. Last in could be a bad (leaking) tankless coil if one is on system. If this doesnt make sense to you please call a pro0 -
Can't improve on that call. Straight to the point.0 -
pressure
I would add to the other suggestions a bad manual fill valve, very common for an old valve to leak through a bit. If you enjoy plumbing I would change the old valve.0 -
Relief valve
And to think no one thought to ask what the static pressure was in the boiler...0 -
Sometimes relief valves just leak. If there is nothing causing too high of pressure, just replace it.
Dave in DenverThere was an error rendering this rich post.
it is doing that because,...
it wants attention. *~/:) thats the truth .0 -
Drain expansion tank completely,0 -
I've never had much luck re-charging ex tanks. I usually just replace them. Same with blow offs. Once they go they often won't reseat even if the pressure is right. A test gauge on a hose bibb in the system saves a lot of conjecture. Good luck0
- 167 Indoor-Air Quality
