BURHAMN
burnerman_2
Member Posts: 297
i had my computer set to capital letters i was not yelling and since it was late fri nite sat morn my spelling may not have been the best and finally these boilers are at different locations cann't get the specs til next time i go there okie dokie royboy u guys r hardcore lol
BOILER L1 SERIES
I WAS WONDERING DOES ANY ONE LIKE OR INSTALL MANY OF THESE WE HAVE 3 WE SERVICE ALL ARE COLD STARTS AND ALWAYS PLUGGED UP THE LATEST HAD TO HAVE THE OUTTER GASKET AND BOTH INNTER AND OUTER ROPE GASKET REPLACED AND THE NOZZLE IS SO SMALL WE GO BY TWICE A YEAR TO REPLACE BECAUSE THEY R PLUGGED UP AND THE LITTLE 3/4 INCH PLUG IS DANG HARD TO REMOVE SO WHAT DO U GUYS ALL THINK ROYBOY0 -
why are you?
As I'm trying to read your statement, why are you YELLING? I'll try to reread the message...0 -
I think...
... a little punctuation goes a long way.
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"Contact John "JohnNY" Cataneo, NYC Master Plumber, Lic 1784
Consulting & Troubleshooting
Heating in NYC or NJ.
Classes0 -
What is the co2 set to? What is the breach draft? is this chimney or direct vented? Does the boiler have system bypasses on it? Is there an oil filter on the job, if so is it a low micron filter? This information would help in resolving you problem. Post pictures if possible also.0 -
also
Another often overlooked but large problem is air for combustion. Make sure you have enough, then as mentioned, make sure you have a system bypass. Have you tried contacting Burnham? They are excellent to deal with...0
- 167 Indoor-Air Quality
