BURHAMN
burnerman_2
burnerman_2 Member Posts: 297
i had my computer set to capital letters i was not yelling and since it was late fri nite sat morn my spelling may not have been the best and finally these boilers are at different locations cann't get the specs til next time i go there okie dokie royboy u guys r hardcore lol
  • burnerman_2
    BOILER L1 SERIES
    I WAS WONDERING DOES ANY ONE LIKE OR INSTALL MANY OF THESE WE HAVE 3 WE SERVICE ALL ARE COLD STARTS AND ALWAYS PLUGGED UP THE LATEST HAD TO HAVE THE OUTTER GASKET AND BOTH INNTER AND OUTER ROPE GASKET REPLACED AND THE NOZZLE IS SO SMALL WE GO BY TWICE A YEAR TO REPLACE BECAUSE THEY R PLUGGED UP AND THE LITTLE 3/4 INCH PLUG IS DANG HARD TO REMOVE SO WHAT DO U GUYS ALL THINK ROYBOY
  • why are you?
    As I'm trying to read your statement, why are you YELLING? I'll try to reread the message...
  • JohnNY
    JohnNY Member Posts: 3,341
    Consulting & Troubleshooting
    Heating in NYC or NJ.
    Classes
  • tk_3
    tk_3 Member Posts: 36
    What is the co2 set to? What is the breach draft? is this chimney or direct vented? Does the boiler have system bypasses on it? Is there an oil filter on the job, if so is it a low micron filter? This information would help in resolving you problem. Post pictures if possible also.
  • lchmb
    lchmb Member Posts: 2,997
    also
    Another often overlooked but large problem is air for combustion. Make sure you have enough, then as mentioned, make sure you have a system bypass. Have you tried contacting Burnham? They are excellent to deal with...
