boiler problem
lchmb
lchmb Member Posts: 2,997
When you say it goes out, does it have a manual reset limit on it? Or is the boiler cycling on high limit?
  • Ted  P.
    Ted P. Member Posts: 6
    boiler problem
    I have had this problem for sometime a hot water boiler that is set at 180* degrees f. and a high limit that is set at 205* f. that goes out on the high limit.
    Can anyone help?
    Ted
  • Ted  P.
    boiler problem
    It goes out on high limit, manual reset and it is driving me crazy.
    I took the air out of the system and it works fine for a few days and then goes off again on the high limit.
    THANKS FOR RESPONDING!!
  • JK_3
    JK_3 Member Posts: 240
    Is the system a loop or monoflo and are all rads and return getting hot? is the circulator running?
