boiler problem
lchmb
When you say it goes out, does it have a manual reset limit on it? Or is the boiler cycling on high limit?
boiler problem
I have had this problem for sometime a hot water boiler that is set at 180* degrees f. and a high limit that is set at 205* f. that goes out on the high limit.
Can anyone help?
Ted0 -
boiler problem
It goes out on high limit, manual reset and it is driving me crazy.
I took the air out of the system and it works fine for a few days and then goes off again on the high limit.
THANKS FOR RESPONDING!!0 -
Is the system a loop or monoflo and are all rads and return getting hot? is the circulator running?
- 87.8K THE MAIN WALL
- 129 Chimneys & Flues
- 123 Geothermal
