Belt Size
Al Letellier_9
Member Posts: 929
Keep a Grainger catalogue in your truck...has many of those formulas in the back...great reference tool
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=248&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
Belt size
Any one know the formula for finding the right size drive belt. Also any links to any HVAC, mechanical equations/formulas etc would be appreciated0 -
Down and dirty
Here you go:
1 - Measure the center-to-center distance between the drive and driven shafts
2 - Mulitply the result in "1" by 2
3 - Measure the effective diameter of the drive and drvien pulleys (By effective I mean the diameter of the smallest pully that can be used to accomodate the belt at its present position in the pulley)
4 - Plug the pulley diameters into the following:
3.14 x (D1 + D2) / 2
5- Add the result from #4 to the result from step #2. This will give the approximate belt length you will need.
The further the shafts are from each other, the more accurate this estimate will be.0 -
OR....
The way I was taught "back in the day"...Take a piece of clothesline and string it around the pully's, with the motor adjusted somewhere near the lower end of the adjustment. Measure the lenth and VIOLA !
The math is easy but this hasn't failed me yet.(Sometimes it's quicker too!).
Sorry Eugene, Some things are just simpler than MATH!) Chris0 -
Thank
you, I have it somewhere but when I needed it the most I could not find it. So now I am trying to put together all the formulas and equations I can find for my laptop so they will be there when needed.0 -
No need to be Sorry
I've been known to "string it" every now and then!0 -
pulley dia
> appreciated
pulley dia
Measure the effective pulley dia times 1.57, do this for both pulleys, then measure the shaft center to center distance times 2. Add the 3 numbers together to arrive at belt length.
We used this many times in the farm equipment business.0 -
I Thought....
I thought that's what I said ?!0 -
Belt size...
Seriously guys... you don't wanna know my belt size. It's why i had to mostly quit the trade.0 -
Belt size
Great--now we need a conversion chart from belts to suspenders...0
- 167 Indoor-Air Quality
