Electric Boiler With O.D.R
stevel
Member Posts: 25
Where abouts are you from,
Concept mfg here in winnipeg makes
an electric boiler with outdoor reset.
hi a friend of mine is building a small home and told me his electric rate is 5.22 cents a kwh. instead of using electric baseboard heaters he wants to use panel rads.
dose anyone know of a good electric boiler that has out door reset. also is electric baseboard heat more efficient then using a boiler?
thanks
Jason0 -
electric boiler
take a look at the Thermolec. It is a very nice boiler!
http://www.thermolec.com/contact.htm0 -
electric boiler
ODR boiler
> thanks Jason
I like the Electro Industries boilers. TS series
www.electromn.com
Check it out.0
- 167 Indoor-Air Quality
