Electric Boiler With O.D.R
stevel
stevel Member Posts: 25
Where abouts are you from,
Concept mfg here in winnipeg makes
an electric boiler with outdoor reset.
  • Rodney Summers
    Rodney Summers Member Posts: 748
    hi a friend of mine is building a small home and told me his electric rate is 5.22 cents a kwh. instead of using electric baseboard heaters he wants to use panel rads.
    dose anyone know of a good electric boiler that has out door reset. also is electric baseboard heat more efficient then using a boiler?
    thanks
    Jason
  • Tom Simensen
    Tom Simensen Member Posts: 74
    electric boiler
    take a look at the Thermolec. It is a very nice boiler!
    http://www.thermolec.com/contact.htm
  • Tom Simensen
    electric boiler
  • stevel
    ODR boiler
    > thanks Jason
  • bobbyg_2
    bobbyg_2 Member Posts: 139
    I like the Electro Industries boilers. TS series
    www.electromn.com
    Check it out.
