radiant in existing slab
realolman
realolman Member Posts: 513
Anyone have any suggestions for installing radiant heat in an existing concrete floor slab?
  • Timco
    Timco Member Posts: 3,040
    A couple guys posted pics a while back showing grooves being cut into existing concrete. Forget who or what it was called...
    Tim
    Just a guy running some pipes.
  • Bump to top, see dilemma post
    Real,
    Someone else is also looking for the post regarding cutting the concrete. Did you ever find it? If so, please post it.
    Thanks,
    Ed Carey
  • Weezbo
    Weezbo Member Posts: 6,231
    a year or two ago Hot Rod posted a thread on a new tool...
    it can roll corners in existing slabs on the pex runs...it looks intensive and i fail to see where the value would be as you could do radiant ceiling and insulate the lid with much better results...i am thinking...
  • Joe Billow_6
    Joe Billow_6 Member Posts: 69
    I would look into the Roth panels. I am going to do an existing slab in them this winter.
  • Todd_17
    Todd_17 Member Posts: 31
    tRY USING A PRODUCT CALLED "BEKO-TEC" , UNKNOWN MANUFACTOR,
    IT ALLOWS YOU TO SNAP TUBING IN AN INSULATED PANEL THAT WILL BE PLACED ON TOP OF AN EXISTNG SLAB. ALLOW AN ADDITIONAL 2-3" OF HEIGHT ON TOP OF EXISTING
  • Don Regan
    Don Regan Member Posts: 43
    We do this often...
    Do you have 2.5" - 3" to work with?
    hot_rod Member Posts: 28,250
    An ugly job, grooving concrete
    John Felciano up in CT actually got his hands on that tool and did a small job. It was built by a diamond saw company in Florida. It was messy and slow as I recall :)
    I'd look at one of the over the top products. something with a little r-value would be helpful.
    hot rod
