Cutting oil
EBEBRATT-Ed
Member Posts: 19,642
What kind of cutting oil do you prefer for threading pipe??
Has anyone noticed any difference in the quality of the threads cut when using different oils. Clear, Dark etc.
I always seem to have better luck with the dark oil.
Sometimes you have to take what the supply house has.
I usually have trouble with tearing threads if I don't use the dark oil. (no it's not the dies)
ED
ED
cut oil
i had trouble making good threads on my ridgid 1224 4"
so i called the rigid rep and they only suggest the use of dark oil and ever since no problem.0 -
Thanks for the reply. I have found that anything other than dark oil dosen't work.
ED0
- 167 Indoor-Air Quality
