Cutting oil
EBEBRATT-Ed
Member Posts: 17,280
What kind of cutting oil do you prefer for threading pipe??
Has anyone noticed any difference in the quality of the threads cut when using different oils. Clear, Dark etc.
I always seem to have better luck with the dark oil.
Sometimes you have to take what the supply house has.
I usually have trouble with tearing threads if I don't use the dark oil. (no it's not the dies)
ED
ED
cut oil
i had trouble making good threads on my ridgid 1224 4"
so i called the rigid rep and they only suggest the use of dark oil and ever since no problem.0 -
Thanks for the reply. I have found that anything other than dark oil dosen't work.
ED0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 938 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
