Lennox Burner
Al K._2
Member Posts: 27
I'm looking for electrode settings and other setup info for a Lennox OHP-31-10-2 oil burner. Parts sources and availability such as transformers and pump drive belts would be appreciated also. I'm recommending furnace replacement in the spring... but it's still winter in New England.
Thanks,
Al K.
Thanks,
Al K.
Good luck
If memory serves you are talking about that great burner Lennox had with belt drive on the pump. Loved that one! My suggestion is to give them a used Beckett for now and then replace or a Carlin EZ1, whichever you have laying around. Tell them the burner was a bad design when new, no parts available and here's a freebee cuz I appreciate your business. Lennos had a round chamber so don't use an older Carlin 99-100 unless you have to, Those burners had long narrow flame patterns that don't get along with round chambers.
You should always have used burners from changeouts hanging around for emergencies. In the summer when slow set some up for 1 pipe and for 2 pipe oil lines and clean them up so all you do is put in the right size nozzle.
That's my 2 1/2 cents.0 -
follow up
my memory is getting clearer- the big problem with these is that the belt slips, even when new, so your pump pressure is always varying-- can't get a good fire out of that!!!!0 -
maybe you should get a new boiler.
or call Singer sewing machines and see if they have the belt for it...0 -
Gawd....
...Like Gino & Weezbo said,send in the sales team.I had customers that I used to service with those burners,horizontal in the attic.:-( I don't miss those gig's at all....
Ya might try a Lennox dealer in your area that's been around awhile (like 35 years or more).Might have one lie'n
around.:-)0 -
South Shore Oil Heat Supply is where I got the last one I needed 508-588-36000 -
Yes, belt driven pump
I managed to get the old girl fired up once again. Got a transformer from a local Lennox dealer as one post mentioned, seems it'd been on their shelf since '94. This burner has lots of noise from the belt idler I think. As I was leaving, I advised the lady to start getting bids for replacement (even from other contractors, but replace the furnace) because more things would be breaking and parts are getting harder to get. The lady says "You found the part this time, why can't you find them next time too?"
Hmm...
Thanks,
Al K.0 -
(sorry, double-posted)0 -
yep
the idler will be the final nail in that coffin. Been there, done that! For your sake, if not hers, put a temporary Beckett on it with a specified time limit so she won't think it's "fixed" for the next 30 years.
May the force be w/ you!0 -
Retrofit Burner
Since this is the second time it's been mentioned...
I think I've got a used AF in storage. Looks like it would need a rather long airtube and a pedestal mount to make it work? I didn't notice a flange, looked like the burner was rubber mounted on a couple brackets.
The lady's not "that" good of a customer, although she is faithful to my company. She only calls for breakdowns. The last time the furnace received a full service was in '98.
Thanks,
Al K.0 -
I have only one thing left to say
about these Lennox burners that are completely unique and have very few interchangeable parts with the rest of the burner world...............................................
WHAT WERE THEY THINKING???????????????????????????????????0 -
Lenox Burner
If the last time it had a service done was in ,98,I would politely ask the customer to find another company to take care of her equipment.
Gary from Granville0 -
It's the Lennox philosophy
Design it in a strange and unique
way, with parts that will have to be ordered only from Lennox, don't give any thought to how well it won't work, then insanely overprice it to boot! 0 -
Which is
exactly why I continue to bad-mouth the line. They are obsessed with prorpietary designs and replacement parts monopolies - based purely on self-interests. Sounds like fre enterprise? Not really. It has back-fired big time and their market share has plummetted. Our local monoploy was bought up by the Keyspan behemouth and they are chokingh violently on the after-taste and numbers that were never there.
Well engineered products with replacement parts that are easy to get rise to the surface and tend to dominate market share, not carefully planned proprietary designs based on the notion "Only WE can supply parts" logic.
