condensate sump float
Tim, if the dimensions are about right and the float will work in hot water (steam condensate) let me know a price.
Larry
  • Larry Gebhardt
    Larry Gebhardt Member Posts: 4
    Condensate sump float
    Need replacement float and actuator arm (details below) for:
    Illinois Condensation Pump - estimate install in steam system in 1950s.
    Mfg by Illinois Engineering Co. Chicago
    Division of American Air Filter Co.
    Size 82 NCR
    S/N SP-4301
    Capacity 8000 ft sq
    20 PSI
    Electric motor est 1/2 HP
    Threads at float end corroded off, float leaking and not buoyant. Float is 7.5 in long, 2 in dia. Threads #10 x 24
    Shaft system is roughly 9 inches long through the case, about 6 inch lever arm, with about 1/2 inch threaded end to mate with float.
  • Timco
    Timco Member Posts: 3,040
    If you can't find the exact part, I have a float w/ a bad seat but fine otherwise you can have to canabalize...sounds somewhat like yours.
    Tim
    Just a guy running some pipes.
  • Timco
    I sent pics to your email, and just replied as well.
    Tim
