condensate sump float
Larry Gebhardt
Member Posts: 4
Tim, if the dimensions are about right and the float will work in hot water (steam condensate) let me know a price.
Larry
Larry
Condensate sump float
Need replacement float and actuator arm (details below) for:
Illinois Condensation Pump - estimate install in steam system in 1950s.
Mfg by Illinois Engineering Co. Chicago
Division of American Air Filter Co.
Size 82 NCR
S/N SP-4301
Capacity 8000 ft sq
20 PSI
Electric motor est 1/2 HP
Threads at float end corroded off, float leaking and not buoyant. Float is 7.5 in long, 2 in dia. Threads #10 x 24
Shaft system is roughly 9 inches long through the case, about 6 inch lever arm, with about 1/2 inch threaded end to mate with float.
If you can't find the exact part, I have a float w/ a bad seat but fine otherwise you can have to canabalize...sounds somewhat like yours.
TimJust a guy running some pipes.0 -
I sent pics to your email, and just replied as well.
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 938 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
