Furnace
gevans
Member Posts: 3
Thermostat is on Heat. The furnace doesn't 'kick' on when the thermostat is turned up and the autoatic fan doesn't come on - But if you leave it on heat and turn the fan ot "on" (runs constantly) heat does blot out of the ducts. Do I need a new thermostat or is this another problem?
when you put it on 'on', are you sure just air is not coming out? It is likely just air, and not heat. This could be anything from a igniter to a spill switch to the gas valve. You should call a pro if you are not mechanically inclined.
TimJust a guy running some pipes.0 -
You mean
it wont "fire", could be anything from a power switch turned off,,,to a pilot light out.
I would suggest calling someone-in for a look see.
Dave0 -
SINCE MOST NEW FURNACES GO BY TIMERS AND NOT HEAT WHEN THERE IS A CALL 4 HEAT IN ABOUT 90 SEC THE FAN STARTS AND SINCE THERE IS NO HEAT BEIN GENERATED IT WILL RUN CONTINULOSLY IT MAY BE OFF ON SAFTY BUT AS OTHERS STATED UNLES U R THERE IT COULD BE 1 OF A DOZ REASONS IT IS OFF ROYBOY0 -
furnace won't kick on
Thermostat is on Heat. The furnace doesn't 'kick' on when the thermostat is turned up and the autoatic fan doesn't come on - But if you leave it on heat and turn the fan ot "on" (runs constantly) heat does blot out of the ducts. Do I need a new thermostat or is this another problem?0 -
no when the thermostat is stet higher than the temperature in th house - hot air comes out. the auto fan just wil not kick on0 -
That sound like a problem in the relay, wiring. or one speed in the fan being burned out! You really need to get someone there to check out the system for you.
The fan "on" on the thermostat normally runs the fan at a different speed than the "auto" fan. The fan controll could be bad, or it could be one of the other reasons mentioned. This is impossible to determine without looking at the unit!
Scott0
- 167 Indoor-Air Quality
