low loss headers
Mike T., Swampeast MO
Member Posts: 6,928
The low-loss header results in the minimum boiler return temperature.
If you're using primary/secondary with a conventional boiler to keep the boiler temperature <I>up</I>--especially in a series of zones--use traditional primary/secondary piping.
low loss headers
when using a primary secondary system, is better to use a low loss header?
why?, and what brand?
thanks
RMA0 -
- 167 Indoor-Air Quality
