low loss headers
Mike T., Swampeast MO
Member Posts: 6,928
The low-loss header results in the minimum boiler return temperature.
If you're using primary/secondary with a conventional boiler to keep the boiler temperature <I>up</I>--especially in a series of zones--use traditional primary/secondary piping.
low loss headers
when using a primary secondary system, is better to use a low loss header?
why?, and what brand?
thanks
RMA0 -
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 938 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
