Heat Pump Chart
Magnehelic
Member Posts: 63
Jack,
Do you happen to have the Air Conditioning version of that Jobsite Information Sheet? I remember when I was in the field doing startup and t-shooting on the Rheem units that the tech support guy from Rheem used to fax those to me and have me fill them out before he would help me. I now am trying to get my technicians to do the same (I was demoted to service manager after my knees/shoulders/and back went south on me). These sheets are awesome for things that aren't obvious.
Thanks Again,
Don
Thanks Again,
Don
Looking for a heat pump chart
Hi Guys 8-)
I am looking for a copy of a heat pump troubleshooting chart. The one that I hope you may be able to help me with is a fill out sheet that has the low and high side gauges as a picture in the middle of it, shows the lineset between the indoor and outdoor unit and pictures of the compressor and reversing valve and other components etc. It has little boxes for filling out the pressures/temps/ampdraws etc.
Does anyone have an electronic copy of this little gem that you can post for me or email to me?
Thanks for all your help in the last 3 years!!! I Love You Guys!
Don0 -
Heat Pump Worksheet
Here, I have this one, hope it helps.0 -
Thanks Jack 8-)
Thanks Jack......this isn't the exact one.....but until I find the exact one......it'll help.
Don0 -
How about this one
This must be the one then.0 -
GSHP/WSHP troubleshooting forms
Don,
See if the attached forms are helpful.
Regards,
Jeff Hammond
Enertech Manufacturing0 -
Start up/ troubleshooting chart
Here's the one we use Don.0 -
Thanks!!! These are EXACTLY what I was looking for!!
Perfect guys.....Thanks so much!!!! Got exactly what I needed!
Don0
