steam boiler indirect tank
joe_61
joe_61 Member Posts: 21
installimg new steam boiler oil fired or should I go with seperate h.w.h oil fired.or idirect tank off of steam boiler.
  • Al Letellier_7
    Al Letellier_7 Member Posts: 7
    hot water off steamer
    A lot depends on what your hot water needs are. The most efficient is a gas tankless heater followed by an indirect off the boiler and the least favorable would be a separate unit or a tankless. Both waste a lot of energy compared to the the other two.
