steam boiler indirect tank
joe_61
Member Posts: 21
installimg new steam boiler oil fired or should I go with seperate h.w.h oil fired.or idirect tank off of steam boiler.
hot water off steamer
A lot depends on what your hot water needs are. The most efficient is a gas tankless heater followed by an indirect off the boiler and the least favorable would be a separate unit or a tankless. Both waste a lot of energy compared to the the other two.0
- 86.2K THE MAIN WALL
- 52 Biomass
- 90 Chimneys & Flues
- 5.4K Gas Heating
- 99 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 63 Pipe Deterioration
- 913 Plumbing
- 6K Radiant Heating
- 380 Solar
- 14.8K Strictly Steam
- 53 Water Quality
- 41 Industry Classes
