bypass and old gravity systems
Harvey Ramer
Member Posts: 2,239
I am converting a gravity system to circulation and adding a radiant floor system. If i do primary and secondary piping and set the gravity system circulator to run continually and install thermostatic radiator valves, is the pump going to burn up if i get a freak warm day.
bypass and old gravity return
installing a burnham scg on a old but fairly small capicity gravity return system it was already changed over to a pumped system...my guestion is this,i am looking for a simple bypass piping schematic with instructions on how to regulate the return temp to keep the temp in the boiler up,any help would be appreciated thanks0 -
Is the boiler not reaching the desired temp with circulation, or are there multi zones and you want return temp protection?
TimJust a guy running some pipes.0 -
bypass
piped boiler today but not quite done. sparky coming to power up monday...this a single zone and i piped the pumbing ayay module with bypass before tie circ....thanks0 -
Most gravity return systems did not have a bypass, and if your system is all on one zone, there is no need for a bypass. I had a gravity return system that was converted and could not get to 180*, and it needed a bypass. Is there a specific reason you want a bypass on a system like this? Could you post a picture?
convert Hot water heater
I use a wood coal stove and want to install a U tube stainless steel pipe in to this stove to preheat my hot water tank in the wintermonths. I would like to do this without a circulator, has anybody got any schematics or drawings how this can be done. I would bypass the stove in
the summer. thanks.
I live in syracuse NY0 -
Sounds like a fine bomb, actually...how would you control the water temp or expansion of the water? A tank in the basement that reaches basement temp alone would help, or maybe a GFX HX?
If you have gravity now (2-pipe) no. You can only use TRVs with a 2-pipe system. Do yo know the required flow rate for your boiler? You will need that info for the pri loop...
Adjust the flow through the boiler for about a 40º delta T0 -
It is a 2 pipe supply and 2 pipe return system. I won't know the flow rate till i get my heat loss calculation back. I'm not quite sure on the proper installation method for the TRV's.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
