Where to purchase 3/4\" Allen Wrench ???
scrook_2
Member Posts: 610
19mm (0.748", used on VW transmission drain/fill plugs in the air cooled days at least, maybe still) will also work perfectly. Check any auto parts supply house, McMaster-Carr (www.mcmaster.com), MSC (www.mscdirect.com), W W Grainger, or even your local Sears.
A 1/2" diameter Hex Head bolt will also have a 3/4" Hex head -- jam two nuts together on it and turn w/ a wrench, or, at worst, grab it w/ Vise-Grip pliers, if you can't find a 3/4 kex key/driver.
Where to purchase 3/4\" Allen Wrench???
I am replacing my old radiator shut-off valves.
The new valves come with a hole for an allen wrench.
Tried to puchase 3/4" allen wrench at several place to no avail. Where would you suggest I locate such large size allen wrench?
Thank you.0 -
type 3/4" allen wrench into Google. There are many results, including Sears.0 -
try www.blackbookoftools.com
They list a long 3/4" for $11.90
Locally? I have no idea.0 -
Try one of the auto parts chain stores... I bought some larger ones that go onto your socket ratchet wrench.0 -
Grainger
Long-arm, #4RE700
- 167 Indoor-Air Quality
