Where to purchase 3/4\" Allen Wrench ???
scrook_2
scrook_2 Member Posts: 610
19mm (0.748", used on VW transmission drain/fill plugs in the air cooled days at least, maybe still) will also work perfectly. Check any auto parts supply house, McMaster-Carr (www.mcmaster.com), MSC (www.mscdirect.com), W W Grainger, or even your local Sears.
A 1/2" diameter Hex Head bolt will also have a 3/4" Hex head -- jam two nuts together on it and turn w/ a wrench, or, at worst, grab it w/ Vise-Grip pliers, if you can't find a 3/4 kex key/driver.
  • Casinojunkie
    Casinojunkie Member Posts: 36
    Where to purchase 3/4\" Allen Wrench???
    I am replacing my old radiator shut-off valves.
    The new valves come with a hole for an allen wrench.
    Tried to puchase 3/4" allen wrench at several place to no avail. Where would you suggest I locate such large size allen wrench?
    Thank you.
  • coalcracker
    coalcracker Member Posts: 51
    type 3/4" allen wrench into Google. There are many results, including Sears.
  • Paul Fredricks_3
    Paul Fredricks_3 Member Posts: 1,556
    try www.blackbookoftools.com
    They list a long 3/4" for $11.90
    Locally? I have no idea.
  • TLynch
    TLynch Member Posts: 19
    Try one of the auto parts chain stores... I bought some larger ones that go onto your socket ratchet wrench.
  • mtfallsmikey
    mtfallsmikey Member Posts: 765
    Grainger
    Long-arm, #4RE70
