If our community has helped you, please consider making a contribution to support this website.  Thanks!
Stolen, uh, parts?
                    Jeff Lawrence_25
                    Member Posts: 746
                    I was able to order the parts from my local York wholesaler.  Took a few more days than I thought it would for me to put my hands on them, but it's done.
Something about allocating the parts at the store level because they kept getting sold out from under me.
            Sometimes, I think I've seen it all
 I do a bit of work for a bank that resells foreclosed houses. I received an email from my contact with them about a stolen condenser that needed replacement.
 Realizing that the 13 SEER rule just came out, for all intents and puropses, I kinda shuddered internally. Usually the foreclosed houses are in a bit of a shambles, and the HVAC system is about the worst.
 I got lucky on this one. The place was already under contract when the agent saw the problem. I ended up going out there (90 minute drive, one way) to actually look at the system.
 I found this.0
            If it had been nearly anything but a Coleman
 I probably would have had to do the entire system.
 The manager of my local York wholesaler and I have known each other for too many years to count, so I stopped by his office and showed him the pictures. "Yep, we can probably get the stuff you need to fix it up," he said.
 The fan guard is is the only thing they'll have to order from the factory, since everything else is in stock (motor, blade, and capicator) I'm waiting on the availability of it, but it looks like good news.
 Sometimes I really love my job.
 Here's the picture of the heat pump inside the place.0
            Hummmmmmmmm
 Something is missing,,,....:-0) Would make a nice out house toilet. I'll bet that thing is quiet.
 Mike T.0
            Only if you have....
 A really large arse!0
            Have it
 We just took out a Coleman. Want our fan grille & motor?0
- 87.2K THE MAIN WALL
- 118 Chimneys & Flues
- 112 Geothermal
- 164 Indoor-Air Quality
- 73 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
