iron speedy headers on condensing boilers
Brad White
Brad White Member Posts: 2,399
I used EZ Headers for my Susan's Vitodens coming off the Low Loss Header on both supply and return.
Made things easy and I like the stable platform on which to support the circulators.
"If you do not know the answer, say, "I do not know the answer", and you will be correct!"
-Ernie White, my Dad
  • chris_93
    chris_93 Member Posts: 84
    iron headers on condesing boiler
    Hi, any issues with using iron speedy headers on my secondary loop. Looking to run 4 high temp zones and this would neaten up and simplify piping. Any thoughts.
    Thanks,
    Mike
  • ALH_4
    ALH_4 Member Posts: 1,790
    Nope
    No problem at all.
  • Brad White
    No problem
    hot_rod Member Posts: 26,651
    Sounds like a good match
    I've also used those iron headers made for CSST piping on a few jobs. Post a pic when you are done.
    hot rod
  • J.C.A._3
    J.C.A._3 Member Posts: 2,980
    Some of them....
    Some E-Z headers I've used have been outstanding...while others seem to send the piping off in another direction.
    Is it bad valves or nipples? Some are really sad looking at from a distance. JCA
