iron speedy headers on condensing boilers
Brad White
Member Posts: 2,399
I used EZ Headers for my Susan's Vitodens coming off the Low Loss Header on both supply and return.
Made things easy and I like the stable platform on which to support the circulators.
-Ernie White, my Dad
iron headers on condesing boiler
Hi, any issues with using iron speedy headers on my secondary loop. Looking to run 4 high temp zones and this would neaten up and simplify piping. Any thoughts.
Thanks,
Mike0 -
Nope
No problem at all.0 -
No problem
Made things easy and I like the stable platform on which to support the circulators."If you do not know the answer, say, "I do not know the answer", and you will be correct!"
-Ernie White, my Dad0 -
Sounds like a good match
I've also used those iron headers made for CSST piping on a few jobs. Post a pic when you are done.
hot rodBob "hot rod" Rohr
Living the hydronic dream0 -
Some of them....
Some E-Z headers I've used have been outstanding...while others seem to send the piping off in another direction.
Is it bad valves or nipples? Some are really sad looking at from a distance. JCA0
- 87.4K THE MAIN WALL
- 167 Indoor-Air Quality
