Is there a standard for
bigugh_4
bigugh_4 Member Posts: 405
Here's googles #s to search
Results 1 - 10 of about 190,000 for maximum oxygen permeation.
  • cruizer
    cruizer Member Posts: 48
    the maximum oxygen permeation rate for rubber, PEX or plastic tubing? I have read that the max recommendation is 0.1mg/l/day. But I believe this was a European standard back in the day when PEX was new to the US.
  • Mike T., Swampeast MO
    Mike T., Swampeast MO Member Posts: 6,928
    German standard DIN 4726 established the maximum O2 permeation rate you mention. It's certainly still referenced in both engineering specifications and manufacturer's literature. Many manufacturers claim permeation rates many times below this level.
    American standards of ASTM F876 and ASTM F877 cover PEX. The ASTM standards do not [appear] to address oxygen diffusion, but I don't have access to the actual ASTM.
    All US contract engineering specs I found mention both the DIN and the ASTM.
