B&G CHECK_TROL iso flanges
ed m
ed m Member Posts: 65
anybody ever use theses, and if so how does the flow check work, have herd mixed reports on the functionality of the flow control, that like the 007 ifc they do not work. just looking for some first hand pro and cons be for i start using them. if they work sounds like a time and money saving product. thanks
eddie
  • Scott Larabee
    Scott Larabee Member Posts: 27
    I've been using them for about a year. I have had no issues at all with them. The are a real time saver, and eliminate a lot of joints, which are always potential leaks.
    As far as I'm concerned, this is a great product.
    Scott
  • bobbyg_4
    bobbyg_4 Member Posts: 6
    I've sold a bunch of them. The only time there was a problem with gravity flow, was from solder getting lodged in the spring check.
    they've been great.
  • Norm Harvey
    Norm Harvey Member Posts: 684
    I love them !
  • Rocky_3
    Rocky_3 Member Posts: 236
    I use alot of them
    especially in retrofit applications where there is a perfectly good pump. Instead of changing the existing pump for an IFC pump, I just install the chek-trol flanges instead. I have not had an issue with them.
    Rocky
