B&G CHECK_TROL iso flanges
ed m
Member Posts: 65
anybody ever use theses, and if so how does the flow check work, have herd mixed reports on the functionality of the flow control, that like the 007 ifc they do not work. just looking for some first hand pro and cons be for i start using them. if they work sounds like a time and money saving product. thanks
eddie
eddie
I've been using them for about a year. I have had no issues at all with them. The are a real time saver, and eliminate a lot of joints, which are always potential leaks.
As far as I'm concerned, this is a great product.
Scott0 -
I've sold a bunch of them. The only time there was a problem with gravity flow, was from solder getting lodged in the spring check.
they've been great.0 -
I love them !There was an error rendering this rich post.
I use alot of them
especially in retrofit applications where there is a perfectly good pump. Instead of changing the existing pump for an IFC pump, I just install the chek-trol flanges instead. I have not had an issue with them.
Rocky0
- 86.7K THE MAIN WALL
- 55 Biomass
- 102 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 935 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
