Night and Day
Supply House Rick
Member Posts: 1,404
One is Darin's the other is anonymous. Can you guess who's is who's? Saw this install the other day. Please feel free to critique... Funny thing is when I showed them Darin's work, they said "hey, he does it like we do!"
Rick
Rick
A Blind Man Could Tell the Difference
And a blind man could have been Darin's competitor....
Well, to be fair, both systems would work (EDIT: aside from the keen observations of UniR and others), but Darin's work is obviously a standard-setter. Things that make you go "Oooh!"0 -
You are doing
the second person a service by showing him Darin's work. Make sure he has a picture to take and peruse. All the difference between the 2 will take time for him to absorb. I remember trying to copy Heatboys style early on (minus the diamond plating)and falling way short. I've gotten a little better each time, but still have a ways to go. WW
How long?
How long has the non-Darin install been dripping condensate directly on the floor?0 -
You could go on and on
How about the extrol leaning back, crooked condensate trap/piping dumping on the floor etc. Was told by customer needed btus to heat the house and that's what I gave him...0 -
How about the extrol leaning back, crooked condensate trap/piping dumping on the floor etc. Here's another angle...0 -
AS Janis would say ...
" OH MY GAWWWDDD "
I'm speechless ......
Scott
Trap
You might want to tell the contractor that they are dumping exhaust out the boiler.The trap needs to be upstream of the boiler condensate.
Dobber0 -
Thank you for the picture of Darin's work .
it has crisp lines , straight , orderly and the piping looks well supported.
i like to see insulation in the rim joist cavity ....it is a biggie to me.call the homeowner and remind him that no matter how well Darin does his work if someone drops the ball on the other end the system suffers ...0 -
Dobber is 100% correct Rick
The way that boiler venting is now, exhaust IS being blown into the house through the PVC drain from the exhaust stack.
The "pro" that piped this put the trap in the wrong place. There is ALREADY a condensate trap in the GB, the exterior trap is for the exhaust condensate only.
That has the potential of killing someone if left as is.
TELL HIM he needs to fix it.
Mark H
Maybe I'm wrong
But if there is a condensate trap then CO could'nt get out of that arrangment ?? Yes or No ??
What am I missing ??
Scott
Scott
Scott, there is a funnel cup under the boiler which indirectly collects the condenstae from the internal trap. Exhaust can leak out of the funnel.
The stellar workmanship shown by Darin is hard for most to follow.
The thing is, on the next job , the other guy ,propbably will do things the same way and not learn from others or himself. Darin, is the kind of installer , who's always looking to improve upon each and every install.
my bad
Shows I should get out in the field more often.
Your rigth Singh. I was thinking it was a sealed trap.
Never Mind
Scott
Long term study
It would be really interesting to follow the service and operating history of these two installs. They are so glaringly different that even the most inexperienced person could see the difference a quality installation is going to make over the long haul.
AFA pointing out issues with the hack job, I keep coming back to the novel approach on the feed water line....... Must be they left it accessible for ease of service.....Other than that, it's a mystery to me. The switch box with no cover is a dandy especially after watching my grandson try to insert a knife (plastic thankfully) into an outlet this evening. I have to assume the guy does not own a level. In addition to that assumption, I'm guessing that he didn't read or can't understand the picture in the manual regarding the vent trap. I would also have to guess that he's trying to eliminate a low humidity problem for the HO by draining the condensate on the floor........I wouldn't sell this guy any more boilers if I were the supply house. His installations will come back to bite you.0 -
Strain reliefs for Romex are available.
If the installer can't find the Romex cable clamps locally, I would be happy to send him some. Do I even want to guess if the ground wires are connected?0 -
Just so everyone understands
I have highlighted the path of the exhaust in the attached pic.
It's one thing to be sloppy, quite another to be clueless.
At the end of the red line is an open cup, much like an indirect waste. There is NOTHING preventing flue gas, a.k.a CO, from being pumped into this home.
It does not matter how cheap this guy sold the job for. I guarantee you the customer expected it would be done correctly AND they never expected that their new, "cheap" system might kill them.
For anyone thinking that "there isn't that much CO coming out of that 3/4" pipe"...... How much Cyanide is safe to drink???
As for the remark that "He does them just like we do".......it would be easy to say that Darin has forgotten more than this team will ever know....except.....Darin does NOT forget. Darin puts the HEALTH AND SAFETY of his customers at the top of the list when it comes to ANY install. I am sick and tired of hearing about jobs being done like this because of the "competitive market" in that particular area. There is no competition between those contractors. They all fall within a few bucks of each other. What they have is a race to the bottom. Looks like this guy is a "winner" in that race.
You really should point this out to the contractor.
I hope there aren't any kids living in that house.
Mark H
This is why
I come here.
Thanks, Mark.0 -
Mark, Thanks for the illustration
I will address this on Friday when I get back to office...0 -
Rick
I'm assuming that you sold them the boiler and any other GB's.You need to make sure that the others are not piped the same way.You may even want to get Buderus involved.
Good Luck
Dobber0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 849 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 58 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
