header vents
scott65
Member Posts: 1
I have none.
my steam lines leading to my radiators don't have header vents . my last radiator has very little heat. what I want to know is how to install them. what kinds should i use
and how far apart they should be.
thankyou.
Scott
thankyou.
Scott
Best Practice
says 15 inches or more back from the end of your main, install them after your last take-off (this is a soft point, idea is to get the air out ahead of the steam) and put the vents at least 6 inches above the main.
The very best advice I can give will cost you only $10 and will do a world of good. Go to the Online Store and look up the SKU#300 item, Gerry Gill and Steve Pajek's guide to balancing steam systems using vents. It comes in a PDF e-book e-mailed to you. Such a deal."If you do not know the answer, say, "I do not know the answer", and you will be correct!"
-Ernie White, my Dad0
- 87K THE MAIN WALL
- 116 Chimneys & Flues
- 109 Geothermal
- 990 Plumbing
- 389 Solar
