help--looking for a vacuum for oil burning boilers
Brandon_3
Brandon_3 Member Posts: 2
Hey guys I could use a little input on what is being used to vacuum up an oil-fired boiler. Right now I use a small shop vac with those paper filters and it clogs in about thirty sec and I end up having to change or knock out the filter about 4-5 times on one boiler. Does anyone have any good suggestions on this subject.
  • Tharon
    Tharon Member Posts: 26
    sootmaster
    Try a Sootmaster vac. R.E. Michels sells them
  • Weezbo
    Weezbo Member Posts: 6,231
    hands down the soot master.
    or if you are thin in the pocket book buy a cheezy shop vac and lotsa hose... put the shop vac out side , clean the boiler , once done go up disconnect the long hose and throw the shop vac in the garbage can.
  • thfurnitureguy_2
    thfurnitureguy_2 Member Posts: 74
    KInd of like a carp recipe I heard of
  • Steve_35
    Steve_35 Member Posts: 545
    The Sootmaster is a great vacuum
    But the first thing we did with it was rip the label off.
  • Billy_4
    Billy_4 Member Posts: 18
    Vac
    The sootmaster is definitely the best. Patriot Supply should have them, you can reach them at 516-249-3100. They are very helpful over there.
  • Boiler Guy
    Boiler Guy Member Posts: 585
    Soot Master
    is top of the line. Milwaukee used to make a good one too. Make sure you get the dacron filter bag for your prefilter.
  • Brandon_3
    thank you for the input
    anyone ever used the HCTV made by the Atrix Corp. The reason I ask is I am looking for something fairly portable and they have a vacuum that is just a bit bigger than a five gallon bucket . Any comments?
  • JaredM_3
    JaredM_3 Member Posts: 12
    Sootmaster
    We own three soot vacs. One is about 25 years old, one about 10 years and the last one five years old. The oldest one works just as well as the newest one. They are all Sootmaster vacs. Sid Harvey sells the same vac with their name. Don't fool around with anything else.
    -Jared
