Cast Iron Radiator
Brstr
Member Posts: 26
Looking for a source for a new or reconditioned CI Radiator that has a height limitation of 19-1/2" for a hot water system. Ideas?
where are you located?
How long of the radiator(s) needed?0 -
CI Radiator
Located in Portland OR. Height is the only limitation, (under window sill) so I am open to column width and length. Found one in Montreal that is 54" length and 12" wide, but freight is a killer on 535lbs!0
- 167 Indoor-Air Quality
