Cast Iron Radiator
Brstr
Brstr Member Posts: 26
Looking for a source for a new or reconditioned CI Radiator that has a height limitation of 19-1/2" for a hot water system. Ideas?
  • where are you located?
    How long of the radiator(s) needed?
  • Brstr
    CI Radiator
    Located in Portland OR. Height is the only limitation, (under window sill) so I am open to column width and length. Found one in Montreal that is 54" length and 12" wide, but freight is a killer on 535lbs!
