New Project
Jeff Elston
Member Posts: 289
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=405&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
What a mess
Not for long soon some Lochinvars for heat and DHW. Dose the word neglect come to mind
What sort
of building is this, Jeff?Retired and loving it.0 -
Building
This is an apartment house about 200 or so dose this room serve. The Federal goes and I am putting in 3 Lochinvar Copperfin 1796.. It will be a 6" P/S manifold. The three way comfort valve has already been removed by someone else, this right now is a winter-summer setup, and with no three way the 6' main were 180* about 100' down the run yikes. Those are some hot hallways in the summer not to mention with no loop reset in the winter the tenants were using the classic window thermostat very wasteful.
Nice.
Quite a change in strategy. Tell me about how you sold it.Retired and loving it.0 -
Nice cutting torch job to get the old one out of their.
ED0 -
Sell?
Whats that , I don't do the selling. But I imagine the fuel bill had something to do with it. This the third job for this cust. the last two were Cleverbrooks changed to copperfinII 2070 I put in 6 in that room and the other I put in 8 peerless 211a-09 quite a job. What I did observe at all three of these jobs was the dust covered water treatment pump and chemicals left and forgotten seems to me the new owner moved in and slashed the maintenance cost and therefore his boilers rot and leak. Here's some pics. I love that b-vent, I pitched a different vent option after i did the figuring and realized the sight it was going to be, but cost drives these people. so 3-2-1- TAKEOFF
The End is near
Salvage company started today
There, no leak
There were still lots more fire tubes to plug in case of leak, so far they had only plugged two of them
I suppose those must have been leaking too much.
After saving so much on tube maintenance, it's no wonder they decided to splurge on new boilers.
I kind of like the rocket look. I imagine all the little kids that will draw pictures of their home with the cool half dozen smokestacks. Everyone will know where they live.0 -
vic vs. cop
Have you found that using vic where you did was in the end a $$$ saver? Also what type of pipe dope did ya use? That looks like blu-block. I NEVER had a job not leak with that stuff. On steam we use wick & dope, and tape & dope on hw. No more leaks.0 -
Gruvlok
Yes I find it to save $$$$ the time to assemble is reduced and the skill level needed to assemble is also less. So I can break free and lay out the next bunch of fittings while some helpers work to put together the first bunch. It is Gruvlok from Anvil not Vic I have looked into Vic but they have a short list compared to Gruv. Gruv has A lot of options and the distribution center is close by. As far as the pie do I now use Permatex 14D white stuff its the best I found and yes always tape then dope. By the way the Gruv never leaks PERIOD and if you messed up the lay out take it apart and reuse it the right way.
New Boilers
These are my fitters Brad, Tim and Alan They do great work These are the boilers heating and DHW here here we go!!To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"0 -
Whose head
did you stick on top of the tee in the middle photo? He does not look happy about it.0 -
thats Tim
Tim
You can see more of him in videos "Tough guy Tim"
The new boilers are in and it will be a pipe laying bonanza come Monday
Well, re-attach it!
He is a tough guy, but still needs and uses his head obviously
Nothing like laying the groundwork for major pipe runs. This is a good project; the owners should be pleased!0 -
Nice job, the only thing I noticed however was on the picture with the stacks on the roof. I see a very small wall louver, is that all the combustion air for these units?0
- 167 Indoor-Air Quality
