outdoor reset
Tekmar 256 - Inexpensive, relatively simple to wire. See attachment.
An even easier way is the use Taco EXP relay with the PC700. It is essentially a 256 made to plug into the relay - wire up the sensors and program. See attachment
  • heatguy
    heatguy Member Posts: 102
    outdoor reset
    looking for simple outdoor reset control which uses thermisters for sensors
  • Brad White
    Brad White Member Posts: 2,399
    Tekmar
    has them simple enough or more complicated if you prefer. Very good sensors, very accurate 10 kOhm thermistors.
    "If you do not know the answer, say, "I do not know the answer", and you will be correct!"
    -Ernie White, my Dad
